How to write C-Series Module Inputs to Arrays
Is there an easier way of writing all values on a C-Series input module to an array, other than wiring each channel of the Module to an "Array Build" and building it manually?
Unless I'm missing something, there doesn't seem to be a way to put a reference to the module itself and write all channels to an array. I have 8 Modules, many with 32 inputs and its extremely tedious wiring them all to arrays.
(3,266 Views)
What are you using the C-Series module in?  cDAQ?  cRIO?
It would also help if you shared some of your code so we can better understand your setup.
(3,254 Views)
Whoops, missed that, its a cRio
(3,251 Views)
Hi Lbee,
maybe you want to support this idea?
(3,239 Views)
