How to write 'Enter' key to serial port COM1 ?
Hi Guys,
I want to use VISA write to send the 'Enter' key to the serial port.
How can I do this??
The command I need to send is like  COMMAND+enter key
I tried to add the \r after the command but it didn't work. Could
anyone give me some clue on this? Thanks a lot.
Lee
(10,641 Views)
First, make sure that your text control/constant is set for '\' Code Display. Otherwise you are sending the characters "\" and "r". You might also have to send \n i.e. \r\n.
(10,640 Views)
Thanks a lot!!!    It works!!!!!
Lee
(10,633 Views)
