How to write MDF(Measurement Data Format) file from Labview
How can i write a MDF(Measurement Data Format) file from Labview.Is there any drivers available to write MDF files?
If any one has those details please provide me ASAP.
Thanks & Regards
Wulfi
(6,620 Views)
Have you tried a search?
(6,605 Views)
Yes, but I found nothing. I only find one Example how to read and the DataPlugin for Diadem but nothing to wirte an mdf from Labview.
(6,586 Views)
My understanding is that once you install the plugin you use the storage VIs to read/write the data file. I've never tried this myself, though.
(6,559 Views)
Yes, writing from Diadem. But I want to write from LabVIEW
(6,553 Views)
That's what I meant. The storage VIs are in LabVIEW. They're in the File I/O palette. To be honest, I have never tried this myself, but supposedly that's how it's supposed to work. In theory. There's not a whole lot of documentation on this on the NI site, and the example that is provided has password-protected subVIs (WHY????), so there's no way to see the actual code for the subVI, which is where the real information is.
(6,549 Views)
