How to write TDMS file with two parameters ?
Hello. Im using LabVIEW 2013 with myRIO 1900. I need to know how i can write a tdms file with two parameters. Ive converted my data into waveform using DDT and then wired it into the TDMS write. When i open the file all i get is the sensor readings. I need to know how i can show variation of my sensor input with time or input coming in from any other channel.
Thanks in advance.
(3,355 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YGxCCAW&l=en-US
waveforms only have one timestamp and a delta, which means in waveforms each datapoint is delta-time later than the previous one .. in other words the difference between two datapoints is uniform
since my own measurements are with varying deltas, i have my tdms with a timestamp channel and seperate data channels, so for every data entry there is a corresponding timestamp.
depending on your volume of data stored in tdms it might help doing that yourself
If Tetris has taught me anything, it's errors pile up and accomplishments disappear.
(3,347 Views)
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000x4PcCAI&l=en-US this was informative
(3,340 Views)
Thank You. That was helpful 🙂
(3,317 Views)
