How to write a LabVIEW program for conducting selected arithmetic operation (+, ─, *, or /) of two numeric values?
On the Front Panel, it has 2 Control inputs, one selector, one display showing “The current operation is ....” and 1 output Indicator.
(2,569 Views)
Hi alyh,
Are you starting the same homework as lots of students before you?
Why don't you search the forum for threads about "calculators"?
What have you tried and where are you stuck?
Mind to attach your code?
(2,535 Views)
I have no idea how to select different answers due to the input.
(2,527 Views)
Hi alyh,
Then you should take a class on basic programming (not neccessarily LabVIEW)…
Suggestions:
  • When you want to select between several cases you should use a case structure!
  • Delete that "Selector" control and create an Enum control.
  • Create items in the Enum corresponding to your required math operations.
  • Now wire that Enum to your case structure and "Create a case for each Enum item"…
(2,510 Views)
