How to write a string containing an asterik to an access database.
When updating a string to an access database, the asterik contained in the string is causing an error in the query. How can you get around this?
(2,562 Views)
Hi Ron,
The easiest way would be to send that as text datatype e.g
INSERT INTO mytable (textcol) VALUE ('*')
I just tried that and it works. hope this would work out for you.
A Rafiq
(2,562 Views)
