How to write an Array of UINT32 to binary file without array dimensions
I need to write a binary file of UINT32 without the array dimension and without running the array through a loop extracting each element - any suggestions??.
The LV "Write File" help implies that if "header" is FALSE the dimension is not written but then contracdicts itself with "LabVIEW always writes a variable-length data type below the top-level (that is, contained in the top-level data type) with a header specifying its size."
Cheers,
Wayne
(2,939 Views)
> any suggestions??.
> size."
What this means is that writing an array with header set to FALSE will
not write out the size, but writing a cluster of strings and arrays will
always write the sizes regardless of the header setting.
Greg McKaskle
(2,939 Views)
