10-08-2014 09:00 AM
Hi Xiaowei,
thanks for your reply.
So Arash would have to write a huge tdms-file, and then he can replace the parts he want to write at a specific channel wih "TDMS Set Next Write Position"?
Kind Regards,
Julia
10-08-2014 01:55 PM
Hi Xiaowei,
Thanks for your clarifications. They were so helpfull.
So I hope this still works out when writing a 2D array in specific position of the tdms.
That is using the "TDMS Set Channel Info" for the first time and then for the next writings using the "TDMS Set Next Write Position" to set the pointer at the desired position.
I will just try this out and let you know ![]()
Thanks again.
Arash
