How to write data to CSV file from waveform chart
Yes, that's a very simple problem. So you want relative time in seconds, not absolute time. Typically, the y-axis is vertical, so it is impossible to have a horizontal line along it. Are you sure that your file name is correct? (Horizontal line along Y axis.PNG)
Message 11 of 19
(1,988 Views)
Hello Altenbach,
thank you for your reply. No no my file name is not correct, just for your your reference I have attached the graph. Usually Y-axis is vertical.  Could you please give me your suggestion on save Time and flux density in .csv file(excel), when I run the program. Looking forward to hear from you soon.
vijay
Message 12 of 19
(1,985 Views)
Here's a quick draft. (Make sure you understand e.g. display style for string constants.)
Note that you need to complete some things, for example the "time" should be based on the wait and [i] and contain decimal digits if it can non-integer.
Message 13 of 19
(1,983 Views)
Hello Altenbach,
Thank you for your valuable suggestions. Now I’m successful able to generate a .csv file with Time and Flux. But I have a question that when I try to get the data in .csv, after a while I stop the program and then continue the measurement, again I pressed Run the program, the data is saving from again Time 0 sec onwards not from the stop point. I was not getting exactly same as in graph. Could you suggest for this issue.
vijay
Message 14 of 19
(1,963 Views)
Hello NI Community,
I am working on a Gaussmeter and Thorlabs instruments (Rotary motor DDR25). I am successfully able to run two instruments at the same time. Now I would like to save data into a .csv file. I have connect .csv file path to gaussmeter loop and getting data (Time[s] and magnetic flux density [mT]) as well. Now as per my project I would like to save Rotary motor data (Angle) to the same .csv file. For your reference I am attaching the code in jpg format, could you please check and let me know your suggestions.
Vijay
Message 15 of 19
(1,960 Views)
Some of us won't even try to look at LabVIEW code posted as a static picture.  I wouldn't ask you for help with a complicated C++ program by sending you a screen-shot of a page of code ...
Attach your VI(s) (or compress the folder containing your LabVIEW Project and attach the .zip file).
Bob Schor
Message 16 of 19
(1,957 Views)
Hi vijay,
What else do you expect when restarting you program?
When the "Time" should continue "from the stop point" then you need to store that value in a file and read the file upon next start of your VI!
You just need to attach the angle data to the FormatIntoString function as 3rd parameter...
Bob already told you about the sense of attaching images to code discussion.
Keep in mind: LabVIEW does not understand "code in jpg format", it also does not know how to handle PNG images of code. LabVIEW expects VIs or PNG snippets (which are different to plain PNG images - read the LabVIEW help)!
Btw. keep related discussions in one thread: it really helps to know the background/history of your question!
Message 17 of 19
(1,945 Views)
Hello NI Community,
Thank you so much for your reply. Actually I am working on two instruments Gaussmeter and Rotation motor (DDR25) from Thorlabs. Gaussmeter is used to measure the Magnetic flux density. A rotation motor is used to rotate the magnet holder (Angle). I have synchronized both instruments and able to plot the data. Now my task is to save the both instruments waveform chart data into .csv file. I am able to save gaussmeter data into .csv file (I have connected .csv file path to gaussmeter loop and getting data (Time[s] and magnetic flux density [mT]) as well. )and moreover I have to save rotation motor data (Angle) into the same .csv file (where magnetic flux data is being saved). For your reference I have attached my .vi could you please check it let me know your valuable suggestions.
Thanks & Regards
Vijay
Message 18 of 19
(1,915 Views)
Hi vijay,
please do yourself a favour and (re-)do those "Training resources" to learn LabVIEW basics! Especially those sections explaining "THINK DATAFLOW!"
Once you did that please take a moment to look at your VI (as shown in the image) to recognize why your changes don't work as intended…
Message 19 of 19
(1,911 Views)
