How to write double numbers with point as decimal character
Hi all,
It is probably a stupid question but I really cannot find a solution to my problem.
Both on the front panel and the block diagram every time I write a decimal number I use the point but LabVIEW writes down a comma for the decimal character.
This is really annoying and becomes extremely dangerous when writing commands for an instrument since the point should be the decimal character and the comma is the separator between different arguments for a given command.
How can I solve my problem?
Many thanks in advance!
(1,433 Views)
Accepted by mol90
See Tools->Options...->  section Front Panel - General. Uncheck "Use localized decimal point" and restart LabVIEW.
Paolo
(1,424 Views)
Check out the section on "Localization Codes" here: https://www.ni.com/docs/en-US/bundle/labview/page/format-specifier-syntax.html
You probably want your format to look like this: "%.;%f"
(1,422 Views)
