Hi rachel-d,
It looks like that instrument driver is only one VI, and is not a certified driver. There seems to be a control for "source (A)" which may be what you're looking for as far as setting the amperage. Honestly, you may have better luck starting with a simple GPIB communication program and writing your own VI. You may need to check your device's manual for information on specific commands to set current values, etc. As for excel, you could use the Write to Measurement File Express VI and write your data to a text-based measurement file (.lvm) that is tab deliminated. You can then open this file with Excel. There are also examples you could look at in the NI Example Finder (Help > Find Examples).
Hope this helps!
Adam W
Applications Engineering
