How to write program for step motor with NI9512 controller
Hello to all!
I´m new here in the forum and also a beginner in Labview. I have the stepmotor Powerpac N33HRHJ - LEK- M2- 00 which is connected to the controller NI 9512. I already can control the motor by using the "test mode" in labview but now I want to need to write a simple program for telling the engine something like: 30 sec at 1000 1/s and accelerate smooth. Does anyone have some experience with this?
The next problem is that the step motor is bucking a lot but the description of the controller says that it has an algorithm for a smooth movement. How can I get this- any tricks?
You would help me a lot by giving me some hint or useful links! Thanks in advance!
Philipp
(2,299 Views)
Hi Philipp,
there are several good documents you can use for solving your issue:
Getting Started with LabVIEW NI SoftMotion and C Series Drive Interfaces: https://www.ni.com/docs/en-US/bundle/372874d/resource/372874d.pd
I hope this helps you.
Best regards
Suse
______________________________
Certified LabVIEW Developer (CLD)
(2,278 Views)
