How to write vi to read strain gauge from ni 9237?
Hello, I have a load cell and I build a cable so that it can be connected to my cRIO ni 9237 now. I would like to ask how to build a vi so that the strain gauge can be read? Like when i tried to measure current using ni 9023, the only thing i need to do is to drag the output from the mode AI list and connect it with an indicator. Can i do the same thing with 9237? Is there any easy examples?
I appreaciate any help.
Thank you.
(2,952 Views)
I'm not sure I understand your question about the mode AI list. Try this. Open LabVIEW click on help, select find example, click on search tab, type in strain.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(2,940 Views)
