How to
I'm using a cRIO 9004 with module 9263, but I don't know how to generate signal in the output. So if somebody have a exemple to teach me use this module or some way to do the signal go out of cRIO I thank very much.
I'm posting two exemples, in the "exemple 1.zip" I just used the FPGA Wizard to create a code to getting a signal eletric (volt), I'm getting in numbers of points using a FIFO to send the value from FPGA to  the HOST, with module 9215, so if somebody know how to create a output for this signal help me.
In the "exemple 2.zip" I used the FPGA Wizard to create a code to getting a signal eletric (volt), I'm getting in numbers of points using a FIFO to send the value from FPGA to  the HOST, with module 9215 with module 9215, and a single points continuous to the output with the module 9263.
The VIs are "FPGA.vi" and "HOST.vi"
I'm developing a design in the area of quality of energy in the University, o I need help to use cRIO, thanks.
(2,981 Views)
Verfique o exemplo Analog Output - cRIO, ele contém os VIs do Host e Target para que você possa estudá-las.
Sugiro também que você verifique o tutorial:
Temos diversos tutoriais e exemplos em nosso site para todos os produtos da National.
Dario Camargo
NI Brazil
#1162665
(2,917 Views)
Translation Portugese to English:
Look at the example Analog Output - cRIO, it contains the VIs of Host and Target so you can study them.
I suggest that you check the tutorial:
http://decibel.ni.com/content/docs/DOC-1663
We have several tutorials and examples on our site for all products from NI.
(2,903 Views)
