How would I soft-clip a sine wave?
My goal is to generate both a hard-clipped and soft-clipped sine wave.
The hard-clipping is fine. I simply converted the dynamic data type to an array and fed it into a Coerce and In Range, where the limits were set at what I wanted to clip at.
But how would I soft-clip a sine wave? As in, instead of it just flat-lining at the clipping point, the signal is merely heavily attenuated.
Thank you.
(3,037 Views)
Hard clip, and then do a polynomial interpolation between the clipped and the original.
Check out madbrain's answer here. More ideas are there.
This was just the first hit on Google.
(3,027 Views)
