How?
Hi.. im using labview 7.1 developing a prohject....
this project got using waveform for read signal.... but when i run the waveform(graph). i found the x-Axis of waveform is running in real time... but i wish the waveform graph can start with zero in each time i run it... is it possible?
(3,696 Views)
Hello
Try this: right click on the graph and check "ignore time stamp" and/or "ignore attributes".
cheers
Alipio
"Qod natura non dat, Salmantica non praestat"
(3,677 Views)
Hello alipio...
your method i already tried before... but it seem desn't work... got any idea again?
with regard
Jaxx
(3,651 Views)
Hi
In my labview 7.1, if ignore timestamp is checked, the x scale ranges from 0 to n in dt increments.
Can you post a simple vi showing your problem,please?
Cheers
Alipio
(3,643 Views)
hi.. alipio...
actually my vi is quite complex i really don't know how to simplify it... but in my labVIEW 7.1 i can't find the "ignore timestamp" what i got only is "ignore attribute"... is it that should be ignore both? can you direct me to find the "ignore timestamp"?
thanks!
with regard
Jaxx
(3,638 Views)
Well, see attached doc.
Try first diagram. after wiring a waveform to a graph, ignore timestamp should be available.
Try second too. In graph properties> format and precission, make sure absolute time or relative time are not selected.
Post back if can´t fix it.
Alipio
(3,629 Views)
