after reading in the discussion forums I still cannot solve my DSC Modbus problems.
First I'm confused about register numbering.
Playing around with the registers, which the multiple variable shows, give me the finally success polling values:
Registers in device documentation: 0x0000 - 0x0007 Finally I found them on 300001-300008
Question: Why is the leading 3 needed....?
Sniffing with Ethereal shows me "function 4" is used for reading by Labview.
Question : Howto use Modbus function 3 or (for writing) 5, 6, 15, 16, (read and write) 23?
My biggest problem at the moment:
I want to read register 0x1010 = 4112d it contain a length of process data byte in packed format. Reading ends in exception 0x8BBB0005
Thanks in advance for an answer or just a link with similar problems
