Howto delete trace breaks ? (DSC)
Hallo all,
I have some interrupted traces due to DSC server stop.
DSC server when stopping is going to put some trace breaks to identify that the logging sistem was off.
The trace appears broken for this period.
I would like to remove this breaks in order to have a continuous trace.
Is there a way to  do that ?
thank you
Gianpiero
(2,937 Views)
No traces handy but I believe the breaks are "NaN". There is an opeartor on that comparison pallette to check for NaN. Just do an interpolation between the previous and next and repeat for all value sin the trace.
Ben
(2,930 Views)
Thank you Ben for the workaround. Seems quite an easy task. I will try it asap.
thank you
Gianpiero
(2,907 Views)
