Hp 6632b control
Hi all looking for a method to display how many mA used to charge a lipo battery to full, iv got the cutoff to work I.e when the current drops below 300ma but need a way to determine how many AH it has taken to charge it to full, thanks.
(974 Views)
Looks like there is a LabVIEW driver available - http://sine.ni.com/apps/utf8/niid_web_display.model_page?p_model_id=1740
Are you looking to get inputs on the algorithm to achieve your goal or hire someone to do that for you?
Santhosh
Soliton Technologies
(952 Views)
Unfortunately the driver doesn't work as I'm using rs232 to communicate with it, I have a working vi just can't work out how to calculate and display the mA that the battery has taken to fully charge. So input would be much appreciated.
(931 Views)
