Hung up on "Installing LabVIEW Database Connectivity Toolkit (64-bit)
I have been trying to install LabVIEW 2020 64-bit, and it keeps getting hung up on the step "Installing LabVIEW Database Connectivity Toolkit (64-bit)". I have nine nearly identical machines, and I get the same issue on all nine. I have tried installing 64-bit :LabVIEW twice now, and the same issue occurs.
I also have LabVIEW 2020 32-bit installed on these machines, and they work fine.
Message 1 of 11
(4,367 Views)
If you are not working with really big data structures that require 64-bit memory, why not stick with 32-bit LabVIEW (which, by your own admission, works fine)?  Particularly since this problem is reproducible among all your LabVIEW 64-bit installations ...
Bob Schor
Message 2 of 11
(4,342 Views)
I am a technician at a University in which one of the professors insists on having the 64-bit version of LabVIEW on the machines in his lab. I don't have a choice in the matter.
Message 3 of 11
(4,340 Views)
Does said professor understand that LV 64-bit doesn't have the same level of toolkit support as LV 32-bit, and comes with some oddball bugs not present in LV 32-bit?
NI recommends installing LV 32-bit unless data that you are expecting are larger than what a 32-bit application will allow.
Bill
CLD
(Mid-Level minion.)
Message 4 of 11
(4,334 Views)
Yes he is aware. A particular application in which convolutions are performed on large chunks of data from a high speed DAQ is a particular reason in why insists on the 64-bit version of LabVIEW.
Message 5 of 11
(4,332 Views)
This isn't an answer, but the LabVIEW 2020 Database Connectivity Toolkit Readme describes the LabVIEW Database Connectivity Toolkit, which added support for LV 64-bit for toolkit version 2020.
So, hmmm...
Bill
CLD
(Mid-Level minion.)
Message 6 of 11
(4,312 Views)
I can confirm this issue as well. Is there a workaround?
Message 7 of 11
(4,286 Views)
It looks like despite getting hung up during the installation process, LabVIEW 2020 64-bit did install. I haven't tested it exhaustively, but I was able to make a simple VI.
Message 8 of 11
(4,277 Views)
That's terrible.  😞
Bill
CLD
(Mid-Level minion.)
Message 9 of 11
(4,270 Views)
hi itoma ,
Did find any solution for this issue?
I tried with lv2020sp1_64 installer still facing  the same issue. Tried with db toolkit (64bit) as well but issue remains. In my case also 2020sp1_64 installed successfully but fails at Db toolkit step.
bp
Message 10 of 11
(4,008 Views)
