Hyper Terminal USB Loopback test
Hi
IM trying to use a cellular USB modem from LabView to send a SMS .
I can make it work from Hyper Terminal but as I said I want it to be done automatically from LabView.
To do so i must know what the HyperTerminal really send when i type in something. how can it be done?
thanks
shai
(4,359 Views)
Hyperterminal sends exactly what you type with a CR/LF at the end. Same as the basic serial write and read example does. That's what the \r\n means. Be sure to have '\' Codes Display turned on for the string control/constant.
(4,353 Views)
Can you give some example of how to give the next commend: AT<return>
thanks
Shai
(4,334 Views)
It's simple:
As I said, just make sure you enable '\' Codes Display.
(4,332 Views)
