HyperLink control in boolean palette
some time there is need to display your menu item in application like hyperlinks.
Labview doesnot provide direct solution for this.Smiley Sad
If you want to customize button control to look like hyperlink, It will add too much code including event structure(please Suggest if anyone have efficient solution) which is not really afforadble if you have multiple hypelinks.Smiley Mad
So I suggest that labview should have a built in hyperlink control which will behave like hypelinks when mouse enter and leaves over control and gives Boolean TRUE when pressed. Smiley Very Happy
(2,902 Views)
Accepted by topic author prayas
(2,899 Views)
You might want to post this to the LabVIEW idea exchange, they take suggestions there.
(2,862 Views)
