HyperTrend Control
How do I programatically rename traces in the NI HyperTrend control?
(3,463 Views)
Accepted by topic author fps
Hi Snord,
You can do this based on the programming in a couple of Community examples that we have available.  This example shows you how to programmatically add traces with a specified URL name using property/ invoke nodes.  If you want to just rename these traces instead of adding a new one, you can follow this example to do so.  For the Maximum/ Minimum property that they are reading, you can select to URL and Change to Write to rename this.
Austin S.
Academic Field Engineer
(3,435 Views)
