Hysteresis Question
Is there a Hysteresis .vi or how can I make one up easily?
Tom
(3,516 Views)
What about hysteresis are you trying to find? The amount of lag a measured signal has from its source? This is easy enough to graph, and measuring it should not be too hard. I suspect that this is not what you are after, however. Could you give a few more details?
As for VIs that already do it, I have searched them and on my installation, I found only one example that used the keyword hysteresis: Basic Level Triggering of Waveforms.
I hope that this helps,
Bob Young
(3,516 Views)
"Bob Y." wrote in message
news:5065000000050000007BD30100-1079395200000@exchange.ni.com...
> Bob Young
Ok what I have at present is an ordinary threshold ie VT where
if Vin>VT yout=1
ifVin
like a logic gate. However I would like to add hysteresis so
that when
coming from 1 back to zero the threshold changes.I suppose it is
if Vin>VT+vhys,yout=1
if Vin
I suppose this is some kind of hysteresis
(3,516 Views)
It looks like you are probably using a loop and are asking how to get both this iteration's values and last iteration's values. The way to do this is through the use of a shift-register. Popup on the right or left edge and select "Add Shift Register". Shift registers work by moving the value from the right side this iteration to the left side next iteration. What ever you wire into it on the right, it will supply on the left next iteration.
You can (and often, but not always, should) wire something to the left from the outside of the loop for use the first iteration. This is an initialization value. You will find lots of information in the devzone about initialized shift registers and uninitialized shift registers.
Hope this helps.
Bo
b Young
(3,516 Views)
