I Have an Error Please Help
sorry for my english
i learn vi class in my university
and i try to do property node
and i found this error
dont know how to fix it
thanks a lot
(1,947 Views)
The error dialog is pointing to the Height input being invalid.  What value are you trying to set it to?  I suspect you will have a similar issue with the Width input as well.
(1,937 Views)
You can't change the height of a numeric control.
(1,935 Views)
To change height:
Certified LabVIEW Architect
(1,904 Views)
This actually works, but I don't think that is what you want, right?
(1,903 Views)
Maybe it would be more interesting to know what you are actually trying to do with all this. Is there also an xcontrol involved? What problem are you trying to solve with these properties? What do you expect as a result?
(1,869 Views)
I also wander why they are teaching you property nodes at this stage...
Property nodes are useful of course, but far less important than for instance dataflow and writing clean(er) code.
(1,813 Views)
