I Have problems creating the file .lbs for a CIN.
I need to use code in C in a LabVIEW application, but I have problems creating the file .lbs that I have to include in the CIN node. I can do the file .c well, but I can't generate the file .lbs. I'm using CVI for doing the .c file. Could someone tell me the steps I have to do exactly?
(3,072 Views)
lidia;
Quoting the KnowledgeBase Article 1NTCNQX4, "the detailed instructions on how to create a Code Interface Node from LabWindows/CVI are given in the cvilvsb.h file, which can be found in the LabVIEW\cintools folder". There is also the following example:
Creating a Simple CIN in CVI and Using It in LabVIEW
Regards;
Enrique
www.vartortech.com
(3,072 Views)
Hi Enrique,
Can you resend the Example again please, I think ther is some problem with that file as I am unable to unzip it
(3,072 Views)
T Sreedhar wrote:
> Hi Enrique,
I think you should check that the FTP download is configured right in
your client/web browser and you have no firewall problems. The file
unzips just fine here.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(3,072 Views)
