I NEED To unboundle this Edge Coordinates. to find Distance of the edges
I tried to unbundle this Edge coorinates. But not able to fnd solution . i have attached my vi file
Message 1 of 10
(3,840 Views)
You are working with 1D arrays of clusters. You need to use e.g. "Index Array" to obtain one cluster from the array before you can unbundle it to find the edge-to-edge distance.
Jarle Ekanger, MSc, PhD, CLD
Flow Design Bureau AS
- "The resistance of wires in LabVIEW is not dependent on their length."
Message 2 of 10
(3,811 Views)
thanks a lot 🙂
Message 3 of 10
(3,805 Views)
if you have found a solution that works for you, please mark this topic as solved 🙂
Message 4 of 10
(3,800 Views)
hi JarleEkanger,
                        1.  right now i am going to work in the die correction project. do you any vi files related to that.
                        2. And i need to create .CSV to read and write operation like database (memory) . do u have any vi related to that.
Message 5 of 10
(3,794 Views)
Hi saran,
1. Can you explain "die correction project" before even asking for help on this topic?
2. LabVIEW comes with ready-made functions to handle CSV files (Read/WriteSpreadsheetFile). And you should stick with your older thread for that topic! Don't create double posts!
Message 6 of 10
(3,783 Views)
Hi GerdW.
I thought this spreadsheet question is differ from my old thread.
I need to read and write in a particular cell of .csv file . But in inbuild function . I dont know how to modify
Message 7 of 10
(3,765 Views)
Hi saran,
you don't modify inbuilt functions. NEVER!
With CSV files you need to read and save the whole file, when you want to access a particular "cell" in the data.
CSV files are simple text files, they don't provide special access methods like Excel does…
So read your file, change the array element you want to change and save the file!
Message 8 of 10
(3,757 Views)
I have another question.. to read particular element in array we use index array funcion. To insert or write what function I should use
Message 9 of 10
(3,753 Views)
Hi saran,
use ReplaceArraySubset.
Don't you think such questions are solved by taking the beginner courses offered for free by NI on their website?
Message 10 of 10
(3,749 Views)
