I/O Server (Modbus): How to read registers in the 2XXXX address range?
I'm using a CompactRIO as a Modbus server. To read some process variables (floating point format), According to http://www.gommci.com/pdf/micro-motion-modbus-usage.pdf (Table 8-1), I need to read from register pairs in the 2XXXX range. However, I/O Server doesn't seem to let me read from this range (http://zone.ni.com/reference/en-XX/help/371618J-01/lvmve/dsc_modbus_using/)
How can I access this data?
Thanks!
Certified LabVIEW Developer
(4,003 Views)
Hello JKSH
Did you test it? because the modbus addresses has 6 digits no 5, the first digit is like a function code. So these addresses include the 2XXXX address range.
Function codes. So you use one of those codes depending on the result you expect.
Regards
Frank R.
(3,976 Views)
Hi Frank,
Unfortunately the hardware is on a different site; I'm tasked with writing the first "draft" of the software based on documentation alone.
Thanks for your link to function codes. I think I understand the addressing scheme better now.
Just to confirm: Suppose that the slave uses addresses starting from 1, not 0, just like I/O Server. If I want to read a floating point number from the pair of input registers 20247-20248, I should read the I/O Server data item "F320247", correct?
(3,963 Views)
That's correct
(3,944 Views)
