I/O direction of LabView shared variable?
Can I programmatically change the I/O direction of a LabView shared variable?  I'm using LV 2010 and I'm trying to change the I/O direction of a NI 9403 module programmatically.  Is this possible?
(2,664 Views)
Hi JAF,
I'm assuming your intended purpose is to input and output data through the same DIO line.
In that case, I would recommend using a case structure. You would need to create a case for input data and another case for the output.
Below is a link describing the characteristics of a case structure.
https://www.ni.com/docs/en-US/bundle/labview-api-ref/page/structures/case-structure.html
I hope this helps. BTW, are you using a cRIO? I'm just curious.
Josh L.
(2,637 Views)
