I Only Want to Plot the Entered Data - no 0s
I'm currently reading data points from a text file and plotting them to a waveform graph.  It's working perfectly -except- in instances where there is no data, the graph displays 0 (causing lines straight down to appear in my actual data).  I'd like it to not display anything when there is no data.  Is there a way to configure it to do such?  I'm brand new to LabVIEW.
Sarah
(2,716 Views)
Accepted by topic author SarahAM
Replace the zeroes with NaN.
(2,699 Views)
Perfect, thank you!
(2,666 Views)
