I/Q Rate for RF Transmission
Hello everyone!!
I want to understand I/Q rate in RF Communications & how to set I/Q rate while transmitting a data stream using 16-QAM.
Carrier Frequency = 10 MHz
Modulation : 16-QAM
No. of bits : 256 bits
Bits per Symbol = 4 (16-QAM)
No. of Symbols = 256/4 = 64 Symbols.
Now how to set the I/Q rate for the above input condition & how to carry out this in LabVIEW.
Thanks in Advance.
(1,167 Views)
Hello
What hardware you are using?
Have you tried to use examples?
__________________________________________
The best way to thank, is to give KUDOS
(1,119 Views)
