I-V measurement
You can use the NI IDN to download drivers for Keithley 2600:  http://www.ni.com/downloads/instrument-drivers/
Or do it right from LabVIEW:  Tools > Instrumentation > Find Instrument Drivers.  It will even search for drivers of devices that are plugged in to your PC automatically.
LabVIEW Pro Dev & Measurement Studio Pro (VS Pro) 2019
Message 11 of 48
(2,718 Views)
@560092 wrote:
Hi, I am currently sending voltage pulse and recording I vs Time using 2611 and labview. Attaching the VI. Earlier more than a year back I was using PXI 6221 and then I tried to send pulse using DAQ  and amplify before feeding to device, and faced time problem with finally generated signal. Now I want to source current pulse from 2611. It can allow the required range of current I have mentioned in my earlier post. Not sure which command you are talking about for pulse.
As GerdW strongly emphasized, you should read the manual.  I downloaded it and found, in a matter of minutes, the following commands.
Page 7-33 "ConfigPulseIMeasureV()"  this command accepts a variety of parameters for the puse on/off duration and current output level.  It evaluates whether or not the desired pulse is possible for the equipment.  An example of the code shows a pulse designed with 1 ms on followed by 80 ms off for an output of 5 Amps.  If the pulse train is acheivable, it assigns a tag number for the pulse train.
to initiate a pulse train, you use the command "InitiatePulseTest(tag)" , page 7-104, to initiate the configured pulse train measurements.
Download the reference manual here http://www.keithley.com/products/dcac/currentvoltage/gpmp/?path=2611A/Documents#5 and look up the rest of the commands you need to configure your SMU routine.
Message 12 of 48
(2,715 Views)
I am doing project with Kiethley 2611A .Could you please send me .VI for the image file which you have uploaded...
Thanks in advance.!
Message 13 of 48
(2,696 Views)
Looks like a spam!!
-Same message he is posting without noticing the replies or understanding the content!!!
uday
Message 14 of 48
(2,669 Views)
It was not a spam.Could you upload the .Vi file for keithley 2611A for measuring  swep Voltage and current..!
Message 15 of 48
(2,657 Views)
Your asking for the end result of a forum post asking for help with the IV measurement (so their VI isn't fully operational yet).  I suggest you at least wait until the original poster's problem is resolved, or download the keithley drivers and modify as you need them.
Message 16 of 48
(2,651 Views)
The original poster chose to attach images of the main and subVI instead of code. The original poster has not logged onto the forums for over 2 years so it is unlikely you will be able to get the actual code. The images are a starting point if you want to write your VI. All of the functions are easy to discern but some of the commands are obscured. Your other option is to start fresh with the driver that others have pointed out.
Message 17 of 48
(2,645 Views)
I have downloaded driver file from keithley website
http://www.keithley.com/base_download?dassetid=51950
After downloading tried to run but i get error the error is
VISA Open in Keithley 2600 Series.lvlib:Initialize.vi->KE26XXA Advanced Sweep.vi
The above error i am getting..
Message 18 of 48
(2,617 Views)
Hi yogesh,
that's only the half part of the error message as it only tells the place the error occured...
Which error number?
Which inputs are used?
Message 19 of 48
(2,613 Views)
Actually,I am trying to interface with Keithley 2611A using Labview and i downloaded the driver file which i have mentioned in the prevoius message.
When Run those files i get error and the error number is -1073807346
Let me know is there any additional files for interfacing keithley device in Labview...
Message 20 of 48
(2,599 Views)
