I WOULD LIKE TO DEVELOP A VI WITH DIAL AND BARGRAPH WHERE INDICATOR IS CONSTANT AND VALUES WILL BE MOVING
I WOULD LIKE TO DEVELOP A VI USING ROTARY DIAL OR BARGRAPH WHERE THE POINTER IS STATIONARY AND VALUES WILL BE SCROLLING FROM 0-360DEGREES IN CIRCULAR SHIFT? PLEASE ADVICE
(2,303 Views)
Please don't type in all CAPS.  There is no need to yell.
Please don't make your subject the same as your message body.  The subject should just provide a quick highlight of what you want.
You can use property nodes of the scale of the dial indicator to set the position of the scale values about the entire rotation.
Also search the forums for "compass" or "compass rose".  Some people doing some aircraft simulation need to do the same thing with their compass display.
(2,300 Views)
