I am a learner. Can you please guide me as to how to begin with in labview
Message 1 of 10
(3,332 Views)
labVIEW training
You can also contact your local rep to arrange for a training. You get a certificate at the end too..
Message 2 of 10
(3,331 Views)
I find the best way to lern is have a go! There are lots of examples (help>>find examples) to get you strted. Find an example and look at how it works, using the context help (ctrl+H) to learn more about each of the functions.
David
www.controlsoftwaresolutions.com
Message 3 of 10
(3,315 Views)
To learn more about LabVIEW, I suggest you try looking at some of these tutorials.
Message 5 of 10
(3,294 Views)
Install LabVIEW on a computer, then do those things mentioned in the proceeding posts. When you have questions, come to this forum. We won't do the work for you, but will try to steer you in the correct direction. Have fun, LabVIEW is confusing at first, particularly if you have had a back ground in other, text based, languages, but that diminishes with experience.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
Message 6 of 10
(3,276 Views)
LabVIEW for Everyone is a good book.
Haven't seen the others.
Message 8 of 10
(3,242 Views)
If you want to make yourself familier with LabVIEW environment. You can refer http://zone.ni.com/devzone/cda/tut/p/id/7466
Keep practising LabVIEW.
Hardik Asawa
Message 9 of 10
(3,199 Views)
I find examples as the best way to kick off your labview career. The shortest possible way is something like this.
1) go and check basic tutorials on labview.
2) once you feel you have made your teeth and are comfortable with labview environment its time to start developing
3) Check Examples.
4) Do assignments, give yourself assignments
e.g Make a function generator
      Make an AM FM Modulator
      Prove Central Limit theorem
      Addition of Noise and Filteration
5) This will give you basic experience on labview. Then labview is a very vast language. Though Stalwarts like Ben and Dennis Knutson who regularly post on this forum have come to a level where they can solve just about any problem of any field. Yet i feel comfortable skewing to my field of interest and trying to gather knowledge relevant only to that field as much as possible.
Best of luck. Do these assignments on your own. Take help of all tools available. You'll feel much more comfortable once you've done some real work youself.
Start Wiring Brother. 🙂
Regards
Asad Tirmizi
Design Engineer
Institute of Avionics and Aeronautics
" Its never too late to be, what u want to be"
Using LabVIEW 8.2
Message 10 of 10
(3,193 Views)
