t, or binary files through the plc or micrologix communication port. This would allow me to build a front panel and change certain states of bits or retrieve data from certain files to display on the front panel. Please steer me in the right direction...Another option is to talk to the PLC using Modbus. Several versions of Modbus drivers are available online--or I could send you the ones I use.
The big thing to look at is exactly what you want to do in the end. If you are going to be able to use all the features of the DSC, by all means go for it. It will save you a lot of time.
If however, all you want is a remote front panel for the PLC, the DSC might be overkill. Only you can say.
Look at your entire application and where you can see your work going in the reasonable future.
Mike...
