I am getting the analog data from 4 input channels with 10k samples/ses sa
mpling rate. I want to get the value of data in every sec. so that I can give a 3 real time graphs and then stored them in a file. However, delay occur. Will this be imporved if faster computer is used? or are there some other suggestion in programming?I am using P-75 with 64MB ram and using PC-516 DAQ card with LabVIEW 5.1
(2,566 Views)
mpling rate. I want to get the value of data in every sec. so that I can give a 3 real time graphs and then stored them in a file. However, delay occur. Will this be imporved if faster computer is used? or are there some other suggestion in programming?What kind of structure are you using to achieve this? If you give some info or send an example of your code, someone can help improving it.
(2,566 Views)
