I am having trouble reading a time stamp on a video using OCR
I am trying to read a time stamp that is overlaid on a video, using OCR software, but it will not read it correctly I've tried the OCR Preproccessing and Recognition Config VI's and neither have been able to correct to problem I would appreciate some help
(3,326 Views)
Please post a screenshot of the image in question.
Also, please advise of how you are doing this. I am assuming that you are using IMAQ.
Your problem may be a matter of imaqe quality. This is usually the problem in these types of situations. Be sure you have adequate contrast. If not, enhance it.
(3,326 Views)
Thank you for your response unfortunately I am unable to send this image over the net, but the image quality is very poor. the time stamp has been inserted using an HEI character inserter, and I believe that it is a very old component, I would appreciate any input as to how I would be able to enhance the contrast? Excuse my inexperience but I have just started using LabView, so I need all the help I can get
Thank you
Ernest
(3,326 Views)
Ernest,
As "labviewguru" mentioned a screenshot will help a lot to determine if the problem is the image quality. However if you can't post this image then please review the following links I'm attaching here. They talk about OCR and most important, about Filtering, which is mostly used in Vision for image enhancement, noise reduction, sharpen an image, etc. Please review the links mentioned below and apply some filtering techniques to your image. This may help a lot, personally I've used OCR software and I have required in most cases to apply filtering before running the OCR functions.
Image Filtering Overview
Image Processing
Optical Character Recognition
Here at the Developer Zone, inside the Development Library you will find in the Vision chapter a lot of information that will be helpful for your development. Please review it. In case you require further assistance you can keep posting questions here at the Discussion Forum or give us a call/email (www.ni.com/ask).
Good luck!
Nestor Sanchez
IMAQ/Motion Support
Nestor
(3,326 Views)
In my experience, it is very important that the contrast not only be
very good but also that the characters can be easily distinguished
from the background and that the characters are generally repeatable
and unique. I've had problems with characters "smearing" into the
background so that the OCR can't tell where the background ends and
the character begins.
Beyond the standard NI OCR stuff, you can use a database to map
incorrect whole words to correct whole ones in OCR but this only works
when there is a set of unique words that are significantly different
from each other. It doesn't work on numbers since any number is
generally as likely as any other.
It may be worthwhile to invest in higher quality acquisition equipment
to improve the image quality. If your video source itself is poor
quality, then it won't matter though.
Douglas De Clue
ddeclue@bellsouth.net
nestor wrote in message news:<506500000005000000F68B0000-1023576873000@exchange.ni.com>...
> Ernest,
> href="http://zone.ni.com/devzone/conceptd.nsf/webmain/E69D110920B99E838625685E0081B881?opendocumen...
> href="http://zone.ni.com/devzone/devzone.nsf/webcategories/605B55C3100D02188625685E0076C928?opendo...
> href="http://zone.ni.com/devzone/devzone.nsf/webcategories/E28E087D201C1AD48625685E00824E3C?opendo...
> Good luck!
> Nestor Sanchez
> IMAQ/Motion Support
> National Instruments
(3,326 Views)
I suggest to post this question at the Vision section. There are persons there that dealing with these problems is like breathing.
Nevertheless, I am pretty sure they will start in a similar fashion.
www.vartortech.com
(3,326 Views)
href="http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=8&RFORMNUMBER=3&RHIDETAG=TRU...
like breathing.
(3,326 Views)
