I am in need of 3-way switch
I am in need of 3-way switch VI . NOT slider VI . and i have found 3-way switch but i was unable to inc the size of switch and also when i was trying to change the switch position it was showing the 4 position option.
Please help me on this and plz provide me the switch VI
Thankd and regards
Mahadev
Message 1 of 22
(5,066 Views)
Use a Picture Ring.
Right click on the control and choose Advanced > customize
Resize the picture box to desired size. and also increase and decrease buttons.
I took 3 way switch from this link http://forums.ni.com/t5/LabVIEW/3-way-vertical-toggle-switch/m-p/205289/highlight/true#M116759
and edited to enlarge the size.
Alter the size of Picture and Increase, decrease button.
Message 2 of 22
(5,063 Views)
Hi thanks for the reply ..whenever i used to change the size , infact dec it , boarders are getting erased and i do not want to the select item whenever i click on switch. so plz help me in these issues
Message 3 of 22
(5,056 Views)
Hi can i get switch exactly as the design as attached
Message 4 of 22
(5,053 Views)
Can you upload the images how the switch should appear during each states?
Message 5 of 22
(5,050 Views)
Hi mahadev,
why don't you continue this discussion in the original thread?
Message 6 of 22
(5,044 Views)
I have attached 3-way switch and its states. thanks for the reply ..
Message 7 of 22
(5,037 Views)
One problem which i found in the 3-way switch which u shared .. supoose if i press on that switch it goes to up state, agin if press it comes to middle state and again if i press it comes to down state but my requirement is if on up side it should be up state , again if i press it should come to midlle state , now again if press on up , it should to up state not down state ... the same follows for down state also ...
please help me
Message 8 of 22
(5,019 Views)
Hi mahadev,
"please help me"
We do this now for quite some time!
As said before: Use a picture ring, include your 3 states as individual pictures. Now you can select which state to go...
Message 9 of 22
(5,012 Views)
I am not gettinbg what u mean .. what is picture ring .. how to change the states.
thanks
mahadev
Message 10 of 22
(4,983 Views)
