I believe the DT3152 driver is for a Data Translation image acquisition board. If so, then ImageMill, Alliance Vision, and Graftek are your best sources for NI IMAQ-type LabVIEW drivers. Data Translation themselves may provide a driver for LabVIEW, but I haven't heard of one.
Often times customers will use the software that comes with their third party image acquisition boards to acquire an image and save it to disk, and then open the image up in LabVIEW using the IMAQ Vision toolkit. Unforunately, if you're trying to automate an inspection, this can be difficult. The easiest solution would be to use a National Instruments image acquisition board, which comes with the NI-IMAQ software that works very well with LabVIEW and our IMAQ Vision toolkit. It's g
oing to be a little more expensive than the third party drivers from Graftek or ImageMill, but it will be well supported by NI and work well with our other software and hardware tools.
If you can provide a few more details about exactly what hardware you have and what you'd like to accomplish, then I should be able to recommend software and hardware tools.
Good Luck!
Kyle V
www.ni.com/ask
