I am looking for a control. a standard switch, but with a "Safety Cover"
I have been looking around, with no success, for a control like the one in the enclosed Image...
In a nutshell, 2 steps needed, (with light to indicate when the switch has been activated)
Does this exist?
Message 1 of 15
(5,756 Views)
Hi Pat,
use two switches:
- one to do your intended switch operation
- another one to dis-/enable the first button…
Message 2 of 15
(5,750 Views)
I happen to have used those exact swtiches with guards before to initiate critical processes, but you will have to add your own indicator light.
Link here, further down on the page is the guard that goes over the toggle:
http://www.alliedelec.com/labinal-llc-8500k2/70176366/
-AK2DM
Message 3 of 15
(5,709 Views)
That is what I am currently doing. But I was looking for something that more closely resembles an actual device I am working on
Message 4 of 15
(5,722 Views)
I have used those same exact switches before to initiate critical but irreversible processes. You will have to add your own light though.
Link below and further down the page is the cover guard:
-AK2DM
Message 5 of 15
(5,709 Views)
You can also hide (property node -> visible?) safety cover after it has been pressed and move it back after 1-2 seconds.
Instead of the button you can use slider that you need to move with mouse to "unlock".
If you want to absolutely avoid accidental clicks, you can hide safety cover 1 second after it has been pressed, or require user to hold it for 1 second to "open".
I would also check guidelines of developing industrial user interface. If program looks like mechanical panel it shortens transition time for the operator, but software and hardware solutions are different in nature and one should not completely duplicate another.
Message 6 of 15
(5,711 Views)
Wierd- my intial post did not show up so I posted again.
Message 7 of 15
(5,706 Views)
Guess it just took a while for your first reply to show.
However, I am not looking for the actual switch... I have tons of them 🙂
I am in need of a labview representation of one.
Message 8 of 15
(5,694 Views)
Anything worth saying is worth saying twice.
Lynn
Message 9 of 15
(5,693 Views)
OK, I think that we are on the same page here...
I am not wedded 100% to a photorealistic image of the toggle/cover, but want to "improve" in the current solution where switch 1 "enables" switch 2... (yes, I just wired the 2 in series)
The Indicator is a trivial exercise... but the 2 stage button... not so much
you said, in part...
You can also hide (property node -> visible?) safety cover after it has been pressed and move it back after 1-2 seconds. Instead of the button you can use slider that you need to move with mouse to "unlock". If you want to absolutely avoid accidental clicks, you can hide safety cover 1 second after it has been pressed, or require user to hold it for 1 second to "open".
so I am curious... Are you envisioning an image sitting "on top of" the  switch? toggling it somehow removes it (hides it or moves it over)
If so, can you provide a simple .vi showing how I could do that?
Message 10 of 15
(5,678 Views)
