I am looking for login user with password for main VI and with add user and change password option
I am looking for login user with password for main VI and with add user and change password option.
I attached a vi with this give me some ideas to do this vi.
thank you
sasi
(3,441 Views)
Hello developer help,
I�m not sure I fully understand your question. Are you just looking for general help with this VI? I tried to open it, but it requires two subvi�s that are missing: log.vi and chps.vi. If you reply with a more detailed, specific question I would be enabled to better help you.
Have a nice day!
Robert M
Robert Mortensen
Software Engineer
(3,441 Views)
I want a VI like this sir, Login Name, Password , Add user, Change password options, Administrator should have rights to change the user setings , add user & guest user can only change their password only.
i am sending you the vi go through this and modify the vi and mail me back personally to me to sasi_iiap@hotmail.com sir, the vi i am sending is not compiling check that and replay immediately sir
there r 5 sub vi's i am attaching 3vi's first & other 2 in the next attachment sir
thank you sir
sasikumar m
(3,441 Views)
next 2 vi's
thank you sir
sasikumar m
(3,441 Views)
Sasikumar,
I am happy to research any specific questions you have regarding your application, and even to test your code to see if I can run it on my machine, but it is not the function of National Instruments employees monitoring these forums to debug, modify, or write code for customers. I tried running your code, but am still missing several VI�s: �DeleteOps.vi� and MyAddOp.vi�, as shown in the picture attached below. Please reply with any specific questions about your application, why it is not compiling, what error you are getting, and the missing VI�s, and I will look further into it.
Have a happy day!
Robert M
Robert Mortensen
Software Engineer
(3,441 Views)
Besides what Robert said, I just want to mention that your VI seems overly complex. You might benefit from a redesign and use something like a state machine architecture. You should also try doing a search of the forum with password as a search parameter and see what comes up. I believe there have been examples posted that do similar things that you're looking for.
(3,441 Views)
