I am looking for what type/setup of Read/Write command in RSLogix 5000 to be used with the NI Ethernet I/P Driver
I am working on trying to get LabView to communicate with an Allen-Bradley Compact Logix PLC using the NI Ethernet I/P driver.  I am currently getting errors on both system of a CIP Message instruction error and cannot determine if the problem is in the PLC or the NI.  At this time we are leaning toward the PLC, thus I was wondering if anyone new what type/setup of message read and write to utilize.
(3,469 Views)
I have only had success connecting to RSLogix using RSLinx OPC server which is pretty simple. Haven't tried the Ethernet I/P driver yet. I was just browsing and found this link:  https://decibel.ni.com/content/thread/7483
The link is in the NI Community, NI Labs, Discussions. You should be able to find something there.
(3,462 Views)
supposedly the Ethernet I/P driver should be simple and make string tags available.  This would open up more flexibility between the two software/programs.  NI supplies examples on the NI side but I still have errors and am looking for something on the PLC side.
(3,455 Views)
Hello jabcae,
Thank you very much for posting your questions.
I recommend posting to the PLC Manufacture’s forums.  They will be able to provide more insight on the PLC code.
I also recommend posting this question to the Industrial Communications forum:
http://forums.ni.com/t5/Industrial-Communications/bd-p/260
That forum is monitored by the developer’s of the EtherNet I/P Toolkit. They will be able to assist with the LabVIEW programming.
Thomas C.
FlexRIO Product Support Engineer
(3,410 Views)
