I am rewriting a
program and I have removed all globals from the program. Now whenever I try to open a VI that had a global in it LabVIEW asks me to locate the VI named "". When I hit cancel everything opens fine. I am also converting this from LabVIEW 6.1 to LabVIEW 7.Any suggestions?
(2,879 Views)
program and I have removed all globals from the program. Now whenever I try to open a VI that had a global in it LabVIEW asks me to locate the VI named "". When I hit cancel everything opens fine. I am also converting this from LabVIEW 6.1 to LabVIEW 7.HI.
Just try resaving your vi...perhaps with a different name. There is probably a subvi that is not exactly where it should be in your directory structure. Resaving it will "remind" your vi where to look for all the components
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,879 Views)
program and I have removed all globals from the program. Now whenever I try to open a VI that had a global in it LabVIEW asks me to locate the VI named "". When I hit cancel everything opens fine. I am also converting this from LabVIEW 6.1 to LabVIEW 7.Thank you, but I have tried a Mass Compile. I have also tried to save the VI to another directory as a different name. The only thing that gets rid of this is completely rewriting the VI from scratch. This could prove to be a lot of work if there isn't another solution.
(2,879 Views)
program and I have removed all globals from the program. Now whenever I try to open a VI that had a global in it LabVIEW asks me to locate the VI named "". When I hit cancel everything opens fine. I am also converting this from LabVIEW 6.1 to LabVIEW 7.I was running on this problem too.
I have saved the LV 6.0.2 VIs in a folder named Version1 and its subfolders. I created a new folder named Version2 to hold the new VIs.
Starting from the VI/CTL lowest in the hirarchy I loaded it in LV7 from the original Version1 location. Then I saved it with "Save as..." in the new location. With VIs I wanted to delete something I loaded them from the old location, made the deletion and saved them in the new location. Then I closed LV to let it forget the paths from the old location. Now I could reload the VI again without the dialog asking for the VI named "".
I got the dialog always if I copied the VI to the new location with the Explorer and loaded it in LV 7 from the new location and deleted something in it.
I do not know if the effect is related only to globals because I deleted globals and subVIs.
Waldemar
Waldemar
Using 7.1.1, 8.5.1, 8.6.1, 2009 on XP and RT
Don't forget to give Kudos to good answers and/or questions
(2,879 Views)
program and I have removed all globals from the program. Now whenever I try to open a VI that had a global in it LabVIEW asks me to locate the VI named "". When I hit cancel everything opens fine. I am also converting this from LabVIEW 6.1 to LabVIEW 7.This seems to work except that I've done an extensive amount of work on this program and would lose almost 2 weeks of work if I have to do that for all my subVIs that won't open properly.
(2,879 Views)
