I am running LV2010, will earlier versions of database connectivi​ty toolkit work?
I am running LV2010.  Can I use the earlier version of the database connectivi​ty toolkit with 2010?
(2,306 Views)
This is a quick reply/reference, but this may be your answer:
http://forums.ni.com/t5/LabVIEW/LabView-database-connectivity-toolkit-1-0-1-compatibility-with/td-p/...
This also has some good data in general regarding toolkit version compatibility:
http://www.ni.com/support/labview/lvtool.htm
Haven't done this personally with the db connectivity toolkit however, which you'll now find packaged under the Enterprise Connectivity Toolkit.
Best,
JLS
Sixclear
(2,303 Views)
