I am running a VI with 8 Booleans that serve as selections. Why does it run so slow?
Do the boolean indicators slow down LAbVIEW?
(2,748 Views)
You don't give enough information.
Post an example, or at least explain what you mean by "serve as selections".
Boolean indicators are quite fast - they don't occupy ANY time unless they actually change state.
Steve Bird
Culverson.com
LinkedIn
(2,748 Views)
Did you add a wait statement to your loop of at least 1ms?
Greetings,
André Buurman
"jcra2911" schreef in bericht
news:50650000000800000010D10000-1079395200000@exchange.ni.com...
(2,748 Views)
Not that I experienced. Unless you are in a loop, where you are calling a whole lot of subvi's that may include talking to slow H/W. Or, if you are running with the execution highlighted on(I doubt this). Or, if you are using a whole lot of either the stacked or flat sequence structure, each doing something slow or timed. Just some guesses, since you do not provide enough info.
Khan Kabir
(2,748 Views)
