I am trying to convert latitude and longitude into UTM coordinates.
I am trying to convert latitude and longitude into UTM coordinates. can sombody please help
Message 1 of 11
(8,403 Views)
Here is a program you can use to verify your labview code.
http://www.my3d.com/converter.php
Message 2 of 11
(8,395 Views)
that is not what i am looking for. i was looking for some code on how to do that. thank you any way
vivi
Message 3 of 11
(8,392 Views)
Message 4 of 11
(8,390 Views)
thank you very much for the link.
vivi
Message 5 of 11
(8,385 Views)
A Google search found this link: http://www.uwgb.edu/dutchs/UsefulData/UTMFormulas.HTM
It has the raw formulas as well as a link to an Excel spreadsheet.
Lynn
Message 6 of 11
(8,378 Views)
thanks, i found some in java script and i am using that as the plan for labview code
Message 7 of 11
(8,373 Views)
Hey ViVi, i am also wanting to convert latitude and longitude into UTM coordinates, and i was hoping you could upload the .vi you made.
It would be much appreciated.
Thank.
Message 8 of 11
(7,317 Views)
I have C++ code that is hosted at http://gpsy.com/gpsinfo/geotoutm/index.html. The codes been used now for about 14 years. The site also has links to other implementations.
Chuck
Message 9 of 11
(7,262 Views)
Hi....I am 'anu' from india.
I want to draw 3D plot of aircraft trajetory by using the latitude,longittude and altitude of aircraft is it possible with labview8.5. If you have any similar VI pls share. And is it possible to define a 3D object like aircraft, 2 axis moving objects?
Thanks in Advance
Message 10 of 11
(7,042 Views)
