I am trying to create N random arrays of a given length help please!
I was given this picture last week as a block diagram in order to create N arrays of a specified length M. The array is to have a floating point representation (i.e. the values that make up the array of numbers can be anything specified by myself.
I attach the picture here and was wondering if someone could tell me what the block diagram object to the right of the random number block diagram object is and where I can find it in LabVIEW, also the block diagram object underneath "N random arrays".
Thanks, This picture is from LabVIEW v.6.1, I am using LabVIEW v.7.1.
Alan Homer
Message Edited by alanhomer on 03-21-2006 03:28 AM
(3,242 Views)
Hi Alan,
The function you want is a bundle found on the cluster palette. You need to make the bundle smaller as it comes off the palette with 2 input.
I attach a VI that is a match to the image you sent, this contians everything wired together and should work out of the box.
Regards
JamesC
NIUK and Ireland
(3,234 Views)
Hi Alan....
I did not get ur question....
What u actually want to ask?
Plz elaborate ur question........
Rohit
(3,233 Views)
When I'm working with LabVIEW I would like to know what the block diagram objects are in the picture and where I can find them in the tools palette to create that VI for myself.
ALan Homer
(3,231 Views)
Thanks JamesC. I had almost made the VI but I couldn't find the couple of parts in LabVIEW tools palettes. A great help. Thanks again.
(3,228 Views)
Hello Alan (or Homer?),
have you switched on the online-help of LabView (by Ctrl-H)? It gives you at least the name of the function and in case of subVi's the path to the vi!
(3,222 Views)
Yes I had that on but it is just that it's been a while since I have used LabVIEW and I am getting my head back into it at the moment. Thanks anyway.
(3,217 Views)
