I am trying to design a VI that will identify the position of any overshoots and undershoots from an input array of 100 elements
I am trying to design a VI that will identify the position and number of all overshoot and undershoot values. I have been trying for the past three weeks to solve this problem but I am having difficulty with the output arrays which will store the overshoot/undershoot values. I am using a for loop but when I connect the array indicator the wire from the o/p tunnel to the array indicator shows an errror? Any help would be greatly appreciated
Kadeel
(3,064 Views)
Try right clicking where the wire to the indicator and for loop meets and select "Enable indexing".
Message Edited by Mathan on 11-27-2009 08:39 AM
(3,062 Views)
Hi Kadeel,
what error do you get? What happens when you right-click the loop output and select Create->Indicator?
Why not attach your vi, that you have been working on for 3 weeks?
(3,043 Views)
Jim
(3,032 Views)
