Jryan,
Arrays in LabVIEW are "zero indexed" meaning that the first element in
an array has an index of zero. If you are sure your instrument
should be setting the 4th bit in the status register, then you will
want index 3. You could also use
NI-Spy for a better look at what's happening on the GPIB bus.
Robert Mortensen
Software Engineer
