I am trying to make a Phase Locked Loop and I have to produce a continuous output with the incom
ing data; so I should not use a buffer which is refreshed in every 3 seconds (by this way I am not able to get a continuous output). How am I going to obtain a continuous output signal which uses a continuous buffer (or no buffer maybe), from my DAQ board?When I try to produce a continuous output (a sine wave) according to a continuously changing input data, I see that the sine wave I can get from the DAQ board output has straight horizontal lines between waves. This means the buffer creates a wave, then stops until it fills, and then creates another output sine wave again; so I can't get a continuous sine wave output from the DAQ board. How am I going to deal with it when im
plementing a PLL in labview.
(2,461 Views)
ing data; so I should not use a buffer which is refreshed in every 3 seconds (by this way I am not able to get a continuous output). How am I going to obtain a continuous output signal which uses a continuous buffer (or no buffer maybe), from my DAQ board?Greetings:
It looks like you need to increase your number of samples by quite a bit. Can you supply any more information, such as your sample rate, which DAQ vi you're using, etc?
Eric
Eric P. Nichols
P.O. Box 56235
North Pole, AK 99705
(2,461 Views)
